PAUSE MARKS
Help for Audacity on macOS.
JRHOCKIN
PAUSE MARKS
Post by JRHOCKIN » Sun Jan 10, 2021 9:58 pm
Is there a way to have a selection pause when it reaches its end? And then have it start up again by pressing ENTER? I then want it to pause again after the second selection. THANKS
jademan
Forum Crew
Re: PAUSE MARKS
Post by jademan » Mon Jan 11, 2021 9:17 pm
In a word, no.
There may be a way to do this with mod-script-pipe (see https://manual.audacityteam.org/man/scripting.html) or by writing a Nyquist program. (see https://wiki.audacityteam.org/wiki/Nyqu ... o_Tutorial)
Re: PAUSE MARKS
Post by steve » Mon Jan 11, 2021 9:54 pm
I'm not sure what you are wanting to do, but you can pause by pressing "P".
billw58
Re: PAUSE MARKS
Post by billw58 » Mon Jan 11, 2021 10:38 pm
Make a selection and press the spacebar to play. Playback will stop at the end of the selection and the cursor will return to the beginning of the selection. Press the spacebar to play the selection again.
-- Bill
