How to record from cassette recorder?
Help for Audacity on macOS.
swami7774
Re: How to record from cassette recorder?
Post by swami7774 » Fri Jan 29, 2021 11:12 pm
I will try that but first this: I did an "Audacity" search in "find" and came up with the below screenshot--four separate Audacities. One is labeled "4."
Should I trash it(along with the unnumbered version) and go from there? Because now, neither 2.3.2 nor 2.4.2 shows up in the microphone permissions area.
Screen Shot 2021-01-29 at 6.09.30 PM.png (99.71 KiB) Viewed 220 times
billw58
Post by billw58 » Sat Jan 30, 2021 2:43 am
Right-click on each of the "unknown" Audacity's and select "Get Info". Note the version number of each. I'm curious which version "Audacity 4" is.
Yes, you can probably delete "Audacity" and "Audacity 4".
And please try Audacity 2.4.2 and see if it works.
-- Bill
swami7774
Post by swami7774 » Sat Jan 30, 2021 3:19 am
Will do in the morning. Thanks again for sticking with me on this. Greatly appreciated.
BTW I’m running Big Sur. The profile thing here stops with “Catalina or later.”
swami7774
Post by swami7774 » Sat Jan 30, 2021 4:24 pm
Here’s the info breakdown on the various Audacities:
“Audacity”(the first one listed) is listed as application 2.3.2 and was created on 5/4/19.
“Audacity 2.3.2” is an alias, created on 10/17/19
“Audacity 2.4.2” is an alias created on 6/26/20
“Audacity 4” is listed as an application and was created on 6/20/20.
I now remember creating desktop aliases for each Audacity. So I’ve got 2 versions, each with an alias.
UPDATE: SUCCESS! After determining which Audacity was which, I went back into the microphone permissions area and re-checked “Audacity 4. I was able to record incoming volume from the cassette. I then tried the Aud 2.4.2 alias, and was again able to record—but the ‘USB Codec” line on the Audacity toolbar was grayed out. Not sure if that matters.
So I think we’ve gotten to the nub of the problem.
billw58
Post by billw58 » Sat Jan 30, 2021 4:44 pm
Whew! Glad you've got it working.
I should have noticed that two of those icons were aliases.
Remember, the Device toolbar will be greyed out during recording or playback.
-- Bill
swami7774
Post by swami7774 » Sat Jan 30, 2021 4:45 pm
I wonder if Audacity won’t accept the recording if I open it via the alias. That shouldn’t matter.
Also, judging by your earlier note, Aud 2.3.2 won’t accept it at all.
billw58
Post by billw58 » Sat Jan 30, 2021 4:49 pm
You said in your previous message that when you started Audacity 2.4.2 via the alias, recording worked.
Yes, something weird is apparently going on with versions prior to 2.4.0 on macOS Mohave or later.
-- Bill
Post by steve » Sat Jan 30, 2021 4:52 pm
If I recall correctly, for the 2.4.0 release the Audacity developers had to jump through some hoops to make Audacity work with Apple's new restrictions on software that was not purchased through the Apple Store.
swami7774
Post by swami7774 » Sat Jan 30, 2021 4:57 pm
I remember that too, Steve. As far as I know Audacity can’t record audio directly from a computer thanks to Apple. Previously we could use Soundflower as a workaround but no longer.
billw58
Post by billw58 » Sat Jan 30, 2021 5:37 pm
Soundflower still works (amazingly!). And there is Blackhole which is under active development.
-- Bill
