FFmpeg on Audacity for Big Sur 11.0 M1 chip
Help for Audacity on macOS.
Mikado
Post by Mikado » Sat Jan 09, 2021 1:58 am
Hello - I'm trying to add FFmpeg to Audacity 2.4.2. I've followed all the instructions, but I am now in a loop. The FFmpeg library ended up in Library/ApplicationSupport/audacity/libs. No squiggle in front of the path. So I guess it's in the wrong place. And so Audacity keeps looking. The screenshots below will show the loop. How do I get the FFmpeg installed? Thanks.
I click locate...
Audacity finds the location. I click OK ,back to #1
Or I click browse.Highlight. Click open
And I'm back to browse
billw58
Re: FFmpeg on Audacity for Big Sur 11.0 M1 chip
Post by billw58 » Sat Jan 09, 2021 2:07 am
Look at your third screen-shot. That's the LAME library, not the FFmpeg library. Try again to install the FFmpeg library.
-- Bill
Mikado
Post by Mikado » Sat Jan 09, 2021 3:09 am
Thanks. It works now :-)
tommybender
Post by tommybender » Sun Feb 14, 2021 10:07 pm
Where did you find the FFMPEG library compiled for arm64? I am able to build an FFMPEG binary for arm64, but I'm not able to created a dynamically link-able library as required by Audacity to convert file formats.
[Advertising is not permitted]
Thanks
Post by steve » Mon Feb 15, 2021 12:22 am
I assume that this is so that you can use it on an M1 Mac?
Does this not work? https://manual.audacityteam.org/man/ins ... html#macff
