- Screen Shot 2021-01-09 at 1.46.42 PM.png (197.32 KiB) Viewed 278 times
Error opening sound device.
Joshua5684
Re: Error opening sound device.
As a test, please try removing "BlackHole" and the "Multi-Output device".
Joshua5684
I can't easily remove BlackHole like I can the multi-output but pressing the minus sign, so I didn't, but nothing changed when I removed the multi-output device.
Joshua5684
Perhaps this is relevant. There's nothing under "supported rates."
- Attachments
- Screen Shot 2021-01-09 at 11.58.40 PM.png (178.21 KiB) Viewed 251 times
- Screen Shot 2021-01-09 at 11.58.49 PM.png (185.27 KiB) Viewed 251 times
To remove BlackHole, you will need to uninstall the BlackHole app.Joshua5684 wrote: ↑Sat Jan 09, 2021 11:25 pmI can't easily remove BlackHole like I can the multi-output
I think it is quite likely that BlackHole is creating a conflict which is causing the problem, so I think you should definitely try removing it.
IF removing BlackHole fixes the problem, then it "may" be possible to reinstall BlackHole without reintroducing the problem - we can look into that if relevant.
Joshua5684
I uninstalled it, but there was no change.
Are you able to play audio files with the Apple Music app?
Joshua5684
Yes, all sound in other apps work.
Very strange.
Please open:
Open the "Build Information" tab.
Scroll down to the bottom of the "Build Information" screen.
Take a screenshot and attach it to your reply.
Please open:
Joshua5684
