Error opening sound device.
Help for Audacity on macOS.
Joshua5684
Post by Joshua5684 » Fri Jan 08, 2021 4:38 pm
I'm actually using Big Sur.
I just installed Audacity and FFmpeg. I've tried all the suggestions in the manual, but it still is not working.
billw58
Re: Error opening sound device.
Post by billw58 » Fri Jan 08, 2021 4:50 pm
What is not working? What are you trying to record from? What is the exact error message (including the error code number)?
FFmpeg has nothing to do with recording.
-- Bill
Joshua5684
Post by Joshua5684 » Fri Jan 08, 2021 4:52 pm
I'm just trying to play a sound.
Screen Shot 2021-01-08 at 11.51.25 AM.png (648.67 KiB) Viewed 559 times
billw58
Post by billw58 » Fri Jan 08, 2021 10:56 pm
Try recording something. The Mac system may ask you to give Audacity permission to use the microphone. Grant it. Then see if you can play back.
-- Bill
Joshua5684
Post by Joshua5684 » Fri Jan 08, 2021 11:05 pm
This is what happened.
Screen Shot 2021-01-08 at 6.03.08 PM.png (56.11 KiB) Viewed 510 times
I checked the the sampling rate as the error suggests, and this is was I saw.
Screen Shot 2021-01-08 at 6.03.37 PM.png (200.26 KiB) Viewed 510 times
Screen Shot 2021-01-08 at 6.03.23 PM.png (226.9 KiB) Viewed 510 times
billw58
Post by billw58 » Sat Jan 09, 2021 2:08 am
Try setting the input to 16-bit integer both in Audacity and in Audio MIDI Setup.
-- Bill
Joshua5684
Post by Joshua5684 » Sat Jan 09, 2021 4:35 am
no change
billw58
Post by billw58 » Sat Jan 09, 2021 4:33 pm
I should have asked right away: what version of Audacity are you running?
-- Bill
Joshua5684
Post by Joshua5684 » Sat Jan 09, 2021 5:24 pm
2.4.2
Post by steve » Sat Jan 09, 2021 6:40 pm
In this post http://forum.audacityteam.org/viewtopic ... 23#p413723 you are looking at the recording device.
I assume that you are using "Built-in Output" for playback (?)
What are the settings for the "Built-in Output"?
