Copy/paste not working in 2.4.2 on Mojave
Help for Audacity on macOS.
jarome
Post by jarome » Thu Jan 07, 2021 3:41 pm
I have had intermittent issues with copy/paste from Audacity labels to other labels and have solved this by pasting and copying in/from text editor. But now no sort of paste works for track labels. Copying from label text to text editor also does not work.
I reverted to 2.4.0 and it works.
billw58
Re: Copy/paste not working in 2.4.2 on Mojave
Post by billw58 » Thu Jan 07, 2021 4:08 pm
This is fixed in version 3.0 alpha. Release date is not known for sure, but likely some time in February.
-- Bill
