macro - sample rate conversion
misnoma
Post by misnoma » Thu Jan 07, 2021 3:36 pm
feature request: ability to change/convert sample rate (either in project, or as an export parameter) would be very useful?
If this already exists, someone please tell me?
Thank you so much for this awesome application. :-)
Re: macro - sample rate conversion
Post by steve » Thu Jan 07, 2021 4:12 pm
When exporting, the sample rate is set by the "Project Rate" (lower left corner of the main Audacity interface).
The "Mix and Render" commands also use the "Project Rate".
The "SetProject:" macro command allows you to change the Project Rate.
