When I do an ACX Check, I get a popup window that lists the values of, for example:
Peak Level - 3.5 db Passes
RMS Level - 19.9 db Passes
Noisefloor - 78.3 db Passes
I understand what those numbers mean, but just below those numbers are these:
RMS (A) 0.056537 (-25.0 db)
Noisefloor (A) 0.000078 (-82.1 db)
DC Offset 0.006148%
What do these numbers mean? Do we need to pay attention only to the first three above?
ACX Check Question
Re: ACX Check Question
They mean you have the wrong ACX Check. The older tester has troubles with the newer Audacity, so a newer test was developed.What do these numbers mean?
http://wiki.audacityteam.org/wiki/Nyqui ... #ACX_Check
A-Weighting takes into account that fact that our ears are most-sensitive to mid frequencies so it's a more "realistic" measure of perceived loudness or perceived noise. It's NOT used by ACX. The measurements are usually lower which makes a "better" noise measurement. A-Weighting is commonly used in SPL (sound pressure level = acoustic loudness) measurements.
