Unrecoverable startup error in 2.4.2 and earlier
Help for Audacity on macOS.
jarome
Re: Unrecoverable startup error in 2.4.2 and earlier
Post by jarome » Thu Jan 07, 2021 2:29 pm
2TB Samsung T7
Post by steve » Thu Jan 07, 2021 2:39 pm
steve wrote:
Wed Jan 06, 2021 7:17 pm
I can confirm that exFAT does not work for Audacity's Temp folder.
My speculation is that it may be a permissions issue, as exFAT does not support file permissions.
Close but no cigar.
It's because FAT / exFAT do not support Unix socket files, which are used by Audacity on macOS and Linux for single instance checking.
jarome
Post by jarome » Thu Jan 07, 2021 2:45 pm
So, Audacity needs to somehow check on the file system of the temp directory before accepting a change. At the very least, put a notice in the user GUI that FAT and ExFAT are not allowed.
Post by steve » Thu Jan 07, 2021 3:03 pm
People are working on it.
waxcylinder
Post by waxcylinder » Thu Jan 07, 2021 3:26 pm
That is what is likely to be happening.
Plus there will be stuff about it in the Manual (oh and the 3.0.0 Release Notes).
Peter.
