Unrecoverable startup error in 2.4.2 and earlier
Help for Audacity on macOS.
jarome
Post by jarome » Wed Jan 06, 2021 3:28 pm
On my Mac Pro running Mojave, I tried to move the temporary storage directory from my small boot disk to an external 2 TB USB drive.
When I do the necessary restart to save the settings, Audacity will not restart with an unrecoverable error! I must delete the app and reinstall. I tried this several times.
billw58
Re: Unrecoverable startup error in 2.4.2 and earlier
Post by billw58 » Wed Jan 06, 2021 3:58 pm
On my iMac running Catalina I cannot reproduce this. Is the "SessionData" folder created on the external HD?
-- Bill
jarome
Post by jarome » Wed Jan 06, 2021 5:52 pm
Yes, and in fact, audacity created the folder.
jarome
Post by jarome » Wed Jan 06, 2021 5:59 pm
It was formatted as ExFAT though. I am reformatting it now into MacOS Journaled. That fixed it!
But if exFAT disks are not allowed, Audacity should tell you so.
waxcylinder
Post by waxcylinder » Wed Jan 06, 2021 6:47 pm
Curiously enough I've been testing saving to exFAT USB on Mac with 3.0.0 for a large part of today.
This working mostly fine - albeit extremely slow.
So following your post I tried setting my Temporary files directory to my exFAT USB.
With both 2.4.2 and 3.0.0 latest alpha I get
Audacity Startup Failure
An unrecoverable error has occurred during startup
As folk seem keen for us to support exFat with Audacity on Win and Mac I shall log this as a bug tomorrow.
Thanks for the report, much appreciated :) 8-)
Peter.
waxcylinder
Post by waxcylinder » Wed Jan 06, 2021 6:51 pm
On w10 with 2.4.2 and latest 3.0.0 alpha having the Temporary files directory set on an exFAT formatted USB stick works fine.
So this is just a Mac issue.
Peter.
Post by steve » Wed Jan 06, 2021 7:17 pm
I can confirm that exFAT does not work for Audacity's Temp folder.
My speculation is that it may be a permissions issue, as exFAT does not support file permissions.
Probably not a good idea to use exFAT for a hard drive anyway - the format was developed by Microsoft for flash drives.
waxcylinder
Post by waxcylinder » Thu Jan 07, 2021 10:19 am
Once again Jarome thank you so much for alerting us to this issue, very much appreciated :) 8-)
I have logged this as a P1 (release blocking) bug: http://bugzilla.audacityteam.org/show_bug.cgi?id=2626
I'm glad you quickly found your workaround and thanks for reporting back with that - a question for you:
Q: is your USB drive fast enough for live projects on Audacity ?
I do a lot of QA testing with USB sticks and drives and I always find them painfully slow when used with live test projects?
Thanks,
Peter.
jarome
Post by jarome » Thu Jan 07, 2021 1:29 pm
It is a solid state USB drive, so very fast.
waxcylinder
Post by waxcylinder » Thu Jan 07, 2021 2:15 pm
Thanks for the update info.
Which make and model is it please?
Peter.
