failed to read from a file in C.
marqueschaney
Re: failed to read from a file in C.
Post by marqueschaney » Tue Jan 05, 2021 7:48 pm
Thanks for all yor help by the way Steve!
The size of the data file is blank but the project size is 194 kb. Both the data file and the project are saved on my desktop and playing correctly.
Post by steve » Tue Jan 05, 2021 8:19 pm
Do you know how to make a ZIP archive? If so, make a ZIP containing both the ".aup" file and the "_data" folder. Upload the ZIP file to somewhere that I can access it (for example, share it via dropbox or Google Drive or similar).
I'm thinking that there may be an error in the data - if there is then I should be able to reproduce the problem here, and hopefully recover most of the project.
jademan
Forum Crew
Post by jademan » Thu Jan 07, 2021 12:07 pm
While you are building that zip archive, here's a couple of thoughts; sorry if they've been mentioned before:
1) Try your export with no special characters in the name, e.g., "xyz"
2) Try saving a smaller version of the file, with just say 1 second of audio. (Export Select)
3) For additional thoughts see here: viewtopic.php?p=380956
marqueschaney
Post by marqueschaney » Mon Jan 11, 2021 4:06 pm
Post by steve » Mon Jan 11, 2021 5:03 pm
I finally built those files.
https://drive.google.com/drive/folders/ ... sp=sharing
You need to make the file available to anyone with the link. Currently it can't be downloaded.
marqueschaney
Post by marqueschaney » Mon Jan 11, 2021 5:18 pm
the file is now available. thank you again
Post by steve » Mon Jan 11, 2021 6:17 pm
I've downloaded the AUP and _data folder.
The project opened successfully, and here it is playing:
Perhaps worth doing a health check on your computer disk. Is it a hdd, SSD or something else?
marqueschaney
Post by marqueschaney » Mon Jan 11, 2021 10:17 pm
Awesome! I will say that I had no issue with it playing. I was just having trouble exporting it..
and I'm using an HDD
Can you export this file so I can upload this episode on my podcast, please?
Post by steve » Tue Jan 12, 2021 12:57 am
There was some data corruption in track 3 somewhere around 2:30. I had to remove a short section from that track to be able to export a mix.
I've uploaded the export here (mind the adverts, it's an ad supported service) https://www.sendspace.com/file/06h3c3
16-bit WAV format, 112.91MB
marqueschaney
Post by marqueschaney » Wed Jan 13, 2021 1:43 am
Thank you so much for helping me upload this episode! Can I send you a hat for helping support my podcast?
