Hi,
I have imported a 65mb .wma into audacity and cut the piece I needed to edit. I then saved the project and exported it as a .wav. When I go to play the new edited piece I am not getting the song but a much shorter high pitch screech.
How can I listen to the edited playback while editing.
Could you please advise me where Im going wrong.
Thanks
playback issue
Re: playback issue
<<<new edited piece>>>
Ummmm. You can't play the saved project or the wav file? Both?
Re: playback issue
Audacity doesn't support .wma files. You'll have to find a different piece of software to convert them to a format that Audacity does understand (usually wav or mp3):
http://audacityteam.org/wiki/index.php? ... ileFormats
