Replicating MorphVOX's diode effect
dfsjio
Post by dfsjio » Wed Dec 23, 2020 9:06 pm
How do I replicate MorphVOX's diode effect? I have been hovering on this for a long time but never found a solution. Here is sample audio with the effect: with https://clyp.it/uhpdnaie/withouthttps://clyp.it/rhfxaozv
Trebor
Re: Replicating MorphVOX's diode effect
Post by Trebor » Wed Dec 23, 2020 10:31 pm
... diode effect? ...
I think you mean droid effect.
