Macro to crossfeed L&R
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
jlparsons
Post by jlparsons » Thu Dec 17, 2020 11:07 am
Hi all, I'm looking to make a macro to do the following actions automatically which I can do relatively easily in Audacity;
  • split a stereo track
  • assign each of the resulting tracks to 80% their original channel and 20% the opposite
  • Output as Mp3
I seem to be falling down at the first hurdle. Any idea if this is possible via a macro?
Trebor
Re: Macro to crossfeed L&R
Post by Trebor » Thu Dec 17, 2020 11:56 am
... assign each of the resulting tracks to 80% their original channel and 20% the opposite ...
Steve's channel-mixer plugin does that sort of thing.
jademan
Forum Crew
Post by jademan » Thu Dec 17, 2020 5:22 pm
Output as Mp3
I think you are right. I am not sure that many of the controls in the Track Control Panel are available as macros. :( However, there is another approach using stereo to mono conversion. If you haven't already built steve's effect into a macro, you can try this one:
Code: Select all
Duplicate:
SelectTracks:Mode="Set" Track="0"
Amplify:Ratio="0.63241184"
SelectTracks:Mode="Set" Track="1"
StereoToMono:Use_Preset="<Factory Defaults>"
Amplify:Ratio="0.31622776"
SelectAll:
ExportMp3:
The math is simply percent to dB ration conversion 101. ;) It gives results that correspond closely with steve's plug-in, which is, of course, much easier to use. :D
