Upgrade from 2.3.3 to 2.4.2 showing wrong sample digits
eisblau
Post by eisblau » Fri Dec 11, 2020 12:36 am
Hi folks,
I've upgraded Audacity from version 2.3.3 to 2.4.2 but now the sample digits are not showing their correct values. In the samples field, only the first 3 digits can be seen, and nothing else, regardless the length I select. As you can see in for example in picture 1, the start point at 2,496 seconds is displayed as "080000000" samples, and the selection length of 0,85 seconds is hown as "528000000" Samples, whereas in picture 2 the length of 0,28 seconds is shown as "808000000" Samples.
I've searched the Audacity forums about problems with the sample digits, but no success. Display in seconds seem to work properly, but as I always use sample accurate cutting, I have no clue at the moment how to go on.
Regards Paul
Re: Upgrade from 2.3.3 to 2.4.2 showing wrong sample digits
Post by steve » Fri Dec 11, 2020 10:19 am
How strange. The problem only appears to occur when the language is set to German. I shall log this bug.
As a work around you could select "hh:mm:ss + samples" as the time format.
Post by steve » Fri Dec 11, 2020 10:22 am
Interestingly I see the same bug in Audacity 2.3.3.
Post by steve » Fri Dec 11, 2020 11:56 am
and in Audacity 2.3.2, though in that version I'm also seeing additional weird selection values that don't occur in 2.4.2.
This issue is now logged on the Audacity bug tracker.
I'm surprised that no-one has reported this bug 'till now :shock:
waxcylinder
Post by waxcylinder » Fri Dec 11, 2020 5:43 pm
On W10 it does occur in 2.4.2 and latest alpha 3.0.0
But not in 2.4.1 or earlier (I started testing back at 2.3.0)
This is the bug thread:
https://bugzilla.audacityteam.org/show_bug.cgi?id=2613
Peter
waxcylinder
Post by waxcylinder » Wed Jan 13, 2021 10:12 am
@eisblau - this has been fixed for the upcoming 3.0.0 release of Audacity.
I have just tested a fix that one of the developers made last night and I confirm that it works OK auf Deutsch now with Samples in the Selection Toolbar and the Timer toolbar.
I cannot update our Bugzilla bug-tracker right now as it is undergoing essential maintenance.
Many thanks for bringing this to our attention - very much appreciated :) 8-)
Vielen Dank
Peter.
