Clicking noises - are these mouth clicks?
germanindc
Post by germanindc » Thu Dec 10, 2020 11:23 am
I frequently hear clicks in my recordings (audiobook for ACX).
The computer is in another room, process is on high process priority, Windows 10. Microphone Rode NT-USB.
I can not think of any source in my recording room other than mouthclicks.
These clicks appear frequently and not in room tone measurements.
I attached you two recordings:
- rapid clicks, which sometimes appear and can be removed with the declick tool from this forum
- loud clicks, which sometimes appear and the declick tool does not manage to remove them sufficiently
Are these mouth clicks? If not, what else could they be?
loudclick.wav
(163.16 KiB) Downloaded 15 times
rapidclicking.wav
(275.5 KiB) Downloaded 10 times
Trebor
Re: Clicking noises - are these mouth clicks?
Post by Trebor » Thu Dec 10, 2020 7:10 pm
loudclick.wav (163.16 KiB)
rapidclicking.wav (275.5 KiB)
"Rode NT-USB" is a mono microphone, but there is a stereo-effect on those attachments:
the tracks are not identical, (not dual-mono).
You can instruct Audacity to record in mono in preferences, ( choose "1 channel").
I'm not claiming this will cure your clicking problem, but is worth a try.
( Paul-L's de-clicker plug-in is designed to be used on mono tracks,
If applied to stereo-tracks, unwanted spatial effects can occur ).
jademan
Forum Crew
Post by jademan » Sat Dec 12, 2020 1:15 am
gernamindc, I have never done any audio mastering, and I believe Trebor and/or others here on the forum have, but to my ears, I don't hear anything other than character in either of those recordings. ;)
Trebor
Post by Trebor » Sat Dec 12, 2020 1:37 am
... to my ears, I don't hear anything other than character in either of those recordings ...
The mouth clicks are visible in the spectrogram view ...
Splashy "loudclick" is actually series of clicks mainly around 10kHz, & only ~2ms apart.
Their closeness is why Paul-L's de-clicker will not detect then on default settings.
germanindc
Post by germanindc » Sun Dec 13, 2020 1:15 pm
So do you think those are mouth clicks?
Any ideas/settings how to get rid of them? (already played with mic position, distance, etc...)
Ideally I would be able to run a plugin on the entire file, without having to mark the individual locations.
jademan
Forum Crew
Post by jademan » Mon Dec 14, 2020 10:41 pm
So you and Trebor have much more discerning ears than I do... :D
On a whim, I took Trebor's suggestion and ran the de-clicker on loudclick changing the step size from 5ms to 2ms. To my ears, the "character" has been essentially eliminated. :D I do not know the downside of this change. :|
Also, have you tried recording in mono ?
germanindc
Post by germanindc » Tue Dec 15, 2020 8:47 am
Thank you for your response.
I tried recording mono, this did unfortunately not work.
Could you please post your full settings for declick?
I changed the step size to 2ms as you suggested but this did not affect the click at all :|
jademan
Forum Crew
Post by jademan » Tue Dec 15, 2020 12:24 pm
I hope this helps. :D
