Losing the Stereo
nhmartens
Operating System: Windows 7
Losing the Stereo
Post by nhmartens » Wed Dec 09, 2020 5:12 am
Comparing 2.1.0 on Windows 7 with 2.0.3 on Windows 10.
I record a song from a cassette player connected to each PC into Audacity. The PC10 version doesn't have the 'stereo' sound like it does on the PC7 system.
While recording I'm also watching the meters. The meters on PC7 are uneven, as expected. The meters on PC10 are locked together and show the same level being record, not expected.
I've attached documents showing part of the audio tracks from both systems. PC7 is the windows 7 system and PC10 is the windows 10 system.
I'm not an expert but it looks (and sounds) like PC10 is converting the stereo recording to monaural.
Am I right? Is there a setting on PC10 that I've overlooked that is causing this effect?
Also, I notice that version 2.4.2 is now the current version. Do you think I should update both systems with this version? Will 2.4.2 work on windows 7?
Thanks.
Trebor
Re: Losing the Stereo
Post by Trebor » Wed Dec 09, 2020 11:24 am
... Is there a setting on PC10 that I've overlooked that is causing this effect?
W10 recording is set to mono by default,
here's how make it stereo ... https://youtu.be/59QY0WL3f64
jademan
Forum Crew
Post by jademan » Fri Dec 11, 2020 3:59 pm
Yes, it is also in the manual, see here: https://manual.audacityteam.org/man/faq ... _stereo.3F
nhmartens
Post by nhmartens » Wed Dec 16, 2020 4:41 am
Well, no cigar. First, the You Tube video was for windows 7 but I was able to get past that. My settings are already set properly. See the attachments. The first one is the windows setting and the second is the Audacity setting.
By the way, these settings were already the default.
Any other ideas?
Thanks.
Audacity 1-Windows.png (3.93 KiB) Viewed 621 times
Audacity 2-App.png (2.71 KiB) Viewed 621 times
jademan
Forum Crew
Post by jademan » Thu Dec 17, 2020 3:43 pm
So here are some more thoughts. Are the PCs identical other than Windows version? Could this be a simple wiring issue ? Do they have similar blue line-in jacks? Have you tried using a USB input device ?
nhmartens
Post by nhmartens » Thu Dec 17, 2020 7:29 pm
Both PCs are from Dell. PC7 is a tower system (XPS model) running Windows 7. PC10 is a laptop (INSPIRON model) running windows 10. I also downloaded Audacity 2.4.2 onto PC10. PC7 is still using version 2.1.0.
Both are using USB 2.0 connections.
I've been using PC7 for years. I just started using PC10 for this purpose about a month ago and discovered this problem when I was playing back a song I had transferred from LP to iTunes. It sounded funny and it was a group that LOVES using both channels. That led me to investigate a little further.
So I recorded the same song using both versions of Audacity and I could CLEARLY make out the separate channels on PC7 and not on PC10. As well as watching the recording meters behave differently. The meter on PC10 had both channels in 'lock step' with each other while PC7 showed them with different levels.
Thanks.
Trebor
Post by Trebor » Thu Dec 17, 2020 10:45 pm
I've been using PC7 for years. I just started using PC10 for this purpose about a month ago and discovered this problem when I was playing back a song I had transferred from LP to iTunes ...
Try inverting one of the stereo-channels.
(i,e, split stereo to mono, invert one track, then rejoin into stereo pair).
jademan
Forum Crew
Post by jademan » Fri Dec 18, 2020 6:21 pm
plural? Just to be clear. You are using one USB cassette player using one USB cable plugged either into PC7 or PC10 ?
nhmartens
Post by nhmartens » Tue Dec 29, 2020 7:42 am
To Trebor:
The web site says this technique is used to "Find out how different the stereo channels are: Use the same steps 1 and 2 above on any stereo track. If the audio is just as loud after the steps as before, the channels are very different. "If the result is silence, the track is not really stereo but dual mono, where both left and right contain completely identical audio."
I know they are different because as I stated earlier, when I record them on PC7, the two channels are very distinctively different. The stereo effect is very pronounced. On PC10 the stereo effect is lost.
To jademan, correct. One cassette device, one USB cable to one PC at a time.
Thanks.
jademan
Forum Crew
Post by jademan » Wed Dec 30, 2020 1:10 pm
Sometimes, it makes sense to double-check that you are getting full stereo separation from your headphones.
Check here: https://thegeekpage.com/stereo-sound-is ... indows-10/
and here: https://answers.microsoft.com/en-us/win ... 6518be836a
Generate a tone. Play it. While playing, pan it from left to right. Does the sound move ?
