Audio Cassette Sounds Weird
SamsungASUS
- Operating System: Windows 7
Hi everyone, I don't really know how to use this forum well, so I'll get straight to the point. I had bought two audio cassettes from eBay, and when I played them in my cassette player, something sounded off. There is a buzz in the audio, but I've been reading reviews of my cassette player, and when people had the same problem, they said to buy powerful batteries instead, but I use Ikea rechargeable batteries, so maybe their not powerful enough. But the main thing is the audio quality sounds so terrible for some reason. I have a sample I recorded to maybe explain better, if it's too short, I can get a longer sample. I'm just at a loss and need help.
- Attachments
- sample.wav
- sample
- (1.83 MiB) Downloaded 13 times
Re: Audio Cassette Sounds Weird
The main problem is there are dropouts: pieces are missing ...SamsungASUS wrote: ↑Tue Dec 08, 2020 1:08 am...the audio quality sounds so terrible for some reason ...
sample.wav (1.83 MiB)
This can be due to programs fighting over control of input-devices, or interrupting in some other way ...
https://manual.audacityteam.org/man/faq ... cations.3F
SamsungASUS wrote: ↑Tue Dec 08, 2020 1:08 amand when people had the same problem, they said to buy powerful batteries instead, but I use Ikea rechargeable batteries, so maybe their not powerful enough.
Your rechargeable Ni-MH batteries are nominally 1.2volts, which means they are already "dead" for some devices. If the device works with the batteries, fine, otherwise, try those alkaline alternatives.
BTW, I personally stay away from the regular "heavy duty" batteries as I have experienced too many cases where they leaked and corroded the device I had put them in.
Do other, non-eBay, cassettes experience the same dropouts ?
SamsungASUS
Ok, I guess that explains why there were skips in the audio, but for some reason, I also hear that the music sounds a little scratchy or somehow not sounding clear and perfect. Maybe I'm just imagining that.Trebor wrote: ↑Tue Dec 08, 2020 12:49 pmThe main problem is there are dropouts: pieces are missing ...SamsungASUS wrote: ↑Tue Dec 08, 2020 1:08 am...the audio quality sounds so terrible for some reason ...
SamsungASUS
Ok, so that explains why there is a hum in the audio, so I'll probably get some alkaline batteries from some store. But for some reason the audio sounds scratchy to me. Maybe I'm just imagining stuff.jademan wrote: ↑Tue Dec 08, 2020 1:47 pmSamsungASUS wrote: ↑Tue Dec 08, 2020 1:08 amand when people had the same problem, they said to buy powerful batteries instead, but I use Ikea rechargeable batteries, so maybe their not powerful enough.Yes, I think you are right!
When I remove an alkaline battery from a failing device, I generally test the battery to verify that is the problem. A "dead" alkaline battery (nominally 1.5volts) will measure anywhere between 1.1 and 1.35 volts depending on the device. If they are at say, 1.42 volts, I reluctantly return them to the device and look for another problem.
BTW, I personally stay away from the regular "heavy duty" batteries as I have experienced too many cases where they leaked and corroded the device I had put them in.![]()
Do other, non-eBay, cassettes experience the same dropouts ?![]()
Odds are there will be crackles where the drop-outs occur.SamsungASUS wrote: ↑Tue Dec 08, 2020 6:46 pmOk, I guess that explains why there were skips in the audio,
but for some reason, I also hear that the music sounds a little scratchy ...
If the drop-outs are very brief all you will notice is the crackle where the join occurs.
Try giving Audacity "above normal" CPU-priority to lower the odds it will be interrupted by other processes.
If that does not work try Audacity's free competitor ... https://www.ocenaudio.com/
SamsungASUS
Sorry, but it still has problems even with cpu-priority set higher or using ocenaudio. I can upload another sample if need be.Trebor wrote: ↑Tue Dec 08, 2020 7:56 pmOdds are there will be crackles where the drop-outs occur.SamsungASUS wrote: ↑Tue Dec 08, 2020 6:46 pmOk, I guess that explains why there were skips in the audio,
SamsungASUS
Sorry, but I bought alkaline 1.5 volt batteries, and the cassette player still has hum.jademan wrote: ↑Tue Dec 08, 2020 1:47 pmSamsungASUS wrote: ↑Tue Dec 08, 2020 1:08 amand when people had the same problem, they said to buy powerful batteries instead, but I use Ikea rechargeable batteries, so maybe their not powerful enough.Yes, I think you are right!
If the problem is common to both Audacity & ocenaudio, then it's either other software (Skype?) or Windows.SamsungASUS wrote: ↑Wed Dec 09, 2020 2:02 amSorry, but it still has problems even with cpu-priority set higher or using ocenaudio...
It doesn't sound like a problem caused by Windows audio enhancement,
but you could check enhancements (recording & playback) are switched off ... https://youtu.be/sxnUjiGgBaI
There is no hum on the audio you posted. If you can hear hum on it your playback device is adding it.SamsungASUS wrote: ↑Wed Dec 09, 2020 2:05 am... I bought alkaline 1.5 volt batteries, and the cassette player still has hum.
(If they are home-made recordings it's possible there is mains-hum baked-in when they were created).
