Overdubbing
serge_girard
Overdubbing
Post by serge_girard » Sun Dec 06, 2020 3:50 pm
Hello !
I'm new on this forum and new to Audicity.
I have a simple question: how can I make a recording with first stereo channel my guitar recorded by microphone. This no problem.
Playback is OK. I use a headphone.
Then I do 'Add new track (mono or stereo)' and start recording by pressing the red RECORD button.
Recording is done but I cannot hear my playing nor the first playing !
I use W10-Pro and Audicity 2.2.2.
Thanks, Serge
jademan
Forum Crew
Re: Overdubbing
Post by jademan » Sun Dec 06, 2020 4:08 pm
Try SHIFT-RECORD. :D
If that doesn't work, check the manual here: https://manual.audacityteam.org/man/tut ... bbing.html
serge_girard
Re: Overdubbing
Post by serge_girard » Sun Dec 06, 2020 4:34 pm
Thanks !
jademan
Forum Crew
Re: Overdubbing
Post by jademan » Sun Dec 06, 2020 6:11 pm
:D
