Bypassing effects
zoharwithaz11
Bypassing effects
Post by zoharwithaz11 » Mon Nov 30, 2020 7:51 pm
Hey everyone,
So what I'm trying to do is to have one track of acoustic guitar that I add effects to (filter curve, compressor, etc.) and one of the following options: 1 would e another unaffected channel that can listen to as reference to my editing 2 - just a way to bypass the effects or turn them off and back on again or the same reason of having a reference.
Thanks in advance to all the answerers:)
Trebor
Re: Bypassing effects
Post by Trebor » Mon Nov 30, 2020 8:46 pm
Duplicate the track, apply effects only to one version, then toggle between them.
https://manual.audacityteam.org/man/tra ... ences.html
zoharwithaz11
Post by zoharwithaz11 » Sat Dec 05, 2020 11:35 am
this didn't work
Post by steve » Sat Dec 05, 2020 12:48 pm
this didn't work
What didn't work?
Trebor
Post by Trebor » Sat Dec 05, 2020 12:49 pm
this didn't work
Depending on what version of Audacity you're using, you may have to change the solo-button behaviour to "Multi-track" to toggle between tracks, see ... https://manual.audacityteam.org/man/tra ... ences.html
zoharwithaz11
Post by zoharwithaz11 » Mon Dec 14, 2020 8:16 pm
this didn't work
What didn't work?
even after I duplicated the track, the filter curve changed on both of them. Even I opened the track in ANOTHER PROJECT
zoharwithaz11
Post by zoharwithaz11 » Mon Dec 14, 2020 8:25 pm
Thanks, but still every effect I add is added to both tracks.
jademan
Forum Crew
Post by jademan » Mon Dec 14, 2020 9:45 pm
To apply an effect to a specific track, click on "Select" at the bottom of that track's Track Control Panel before applying the effect.
See https://manual.audacityteam.org/man/aud ... ction.html
I hope this helps. :D
Post by kozikowski » Mon Dec 14, 2020 10:50 pm
You don't have a SELECT button because you have an older version of Audacity.
You can fake one by clicking just right of the up arrow.
Audacity 2.4.2 has a formal Select button down there.
