Can't apply any effect, Value not in range
udrakan
Operating System: Windows 7
Post by udrakan » Mon Nov 30, 2020 3:17 am
https://media.discordapp.net/attachment ... height=676
Windows 7-64bit
Audacity 2.4.2
Hello,
I cannot do any effect, as shown on the picture in link. All values are within bounds, but program says they are not.
I surely have the same problem as this personviewtopic.php?t=91004, because I have Czech keyboard which also uses comma as default decimal separator.
I tried
-going into keyboard language settings and changing it to US, restarted PC
-try manually changing the decimal separator to dot in number formats and currencies and restarting pc
idk what to do anymore and I would prefer not to use other program.
Re: Can't apply any effect, Value not in range
Post by steve » Mon Nov 30, 2020 9:51 am
Open the "Nyquist Prompt" effect (in the "Tools" menu).
Copy and paste this code into the Nyquist Prompt, then click the "Debug" button:
Code: Select all
;version 4
(print *DECIMAL-SEPARATOR*)
What happens?
udrakan
Post by udrakan » Mon Nov 30, 2020 9:27 pm
Hello, thanks for helping me, steve
When I copy the code into nyquist prompt and press debug, it shows this: https://media.discordapp.net/attachment ... nknown.png
Post by steve » Tue Dec 01, 2020 11:06 am
Code: Select all
That means that the decimal separator is the "dot" character.
Are you using a Czech version of Windows?
Is Czech your primary language?
udrakan
Post by udrakan » Wed Dec 02, 2020 3:08 am
No, all windows elements are in english except the keyboard which is a czech keyboard, because I live here, but eng is my primary language.
Trebor
Post by Trebor » Wed Dec 02, 2020 5:59 am
It's not necessary to key-in a decimal point into that particular effect ...
can use the decimal point provided.png (57.11 KiB) Viewed 352 times
Either use the slider, or just type-in numerals, using the decimal-point generated in the fields.
udrakan
Post by udrakan » Thu Dec 03, 2020 8:42 am
Even just selecting an effect and clicking Apply/OK or using slider (not typing anything into any field) will yield the value Not in range error
Post by steve » Thu Dec 03, 2020 10:07 am
If you then launch the same effect again and (without changing anything) apply again, does the same error message appear ?
udrakan
Post by udrakan » Thu Dec 03, 2020 11:20 am
Yes, same error. Even when I'm not changing anything at all in the effect window and just apply it, error appears.
Post by steve » Thu Dec 03, 2020 11:29 am
I don't have Windows 7 (it is now obsolete), but I think the problem is that you have conflicting settings regarding what the decimal separator is. You need to go through the Windows settings and ensure that the decimal separator is either set as a comma in all places, or a dot in all places. Check that in the "Regional and Language Options" that the "locale" ("regional setting") is consistent with the number format settings.
