Opening AUP Files
missmarianelizabeth
Opening AUP Files
Post by missmarianelizabeth » Fri Nov 27, 2020 8:59 pm
Hi Please help.
My audacity seems to have updated something and now I am getting this message on my Windows. I am not great with tech and I just need to know what I need to download to make the files open.
Thanks,
Marian
Screenshot (6).png (28.36 KiB) Viewed 569 times
Re: Opening AUP Files
Post by kozikowski » Fri Nov 27, 2020 10:37 pm
Have you used Audiotonic before?
Instead of double-clicking on an AUP file and let Windows figure it out, Right-Click the AUP file > Open With and point it to Audacity.
Or Open Audacity first. Then File > Open and point it at your AUP file.
missmarianelizabeth
Post by missmarianelizabeth » Sat Nov 28, 2020 7:22 am
Hi Koz
Thank you - It is still saying the same thing in audacity
Is there any other way of opening the files so I can convert them?
jademan
Forum Crew
Post by jademan » Sat Nov 28, 2020 12:08 pm
I am not familiar with "Audiotonic"'. But they seem to be related to Blue Sky Software. We have seen them before:
viewtopic.php?p=406714#p406714
On the surface, this seems to be an Audiotonic error. What did they say when you asked them ?
Post by steve » Sat Nov 28, 2020 1:36 pm
Are you using genuine Audacity (from here: https://www.audacityteam.org/download/windows/) or are you using "Audiotonic" from the Microsoft Store?
If you're using Audiotonic, you should contact them for support.
From their website:
Help & Support
Our commitment to customer satisfaction is backed by our solid customer support service. We provide effective and timely technical support to resolve any issues ranging from software installation, functionality questions, inputs for usability, to bug reports and stability issues.
missmarianelizabeth
Post by missmarianelizabeth » Sat Nov 28, 2020 2:49 pm
So I have made sure that I am using Audacity 2.4.2 from the audacity site. However it is still saying this
Screenshot (8).png (40 KiB) Viewed 530 times
I have editted work on it this morning and it now wont open that saved file. It comes up with the above message
Post by steve » Sat Nov 28, 2020 2:57 pm
Please attach the AUP file to your reply.
missmarianelizabeth
Post by missmarianelizabeth » Sat Nov 28, 2020 3:01 pm
Here are the AUP files, Thank you!
4th Part.aup
(49.44 KiB) Downloaded 17 times
3rd Part Done.aup
(84.63 KiB) Downloaded 12 times
Post by steve » Sat Nov 28, 2020 3:13 pm
Put the original AUP files somewhere safe (as a backup), then download these two files and put them into the original locations for "4th Part.aup" and "3rd Part Done.aup".
3rd Part Done.aup
(84.63 KiB) Downloaded 14 times
4th Part.aup
(49.43 KiB) Downloaded 12 times
missmarianelizabeth
Post by missmarianelizabeth » Sat Nov 28, 2020 3:26 pm
That worked! I have three more files that I need to open that I have attached.
I am so thankful to you. i am sending you a virtual hug!
Thank you,
Marian
5th Part.aup
(75.52 KiB) Downloaded 7 times
6th part.aup
(92.59 KiB) Downloaded 10 times
Pick ups.aup
(17.84 KiB) Downloaded 10 times
