Cannot Get Audacity 2.4.2 to record. Tried everything--even two different computers.
Is anyone having problems getting Audacity to record, or recognize a microphone? I desperately need help with this problems.
Thanks.
Thanks.
Re: Cannot Get Audacity 2.4.2 to record. Tried everything--even two different computers.
You need to give Audacity permission to use the microphone.
Thanks Steve, but I don't think this is the problem. It was fine one day, and the next, this started happening.
So, as I said, I tried my other computer which I was using Audcaity on for years, and the same exact thing occurs.
The green colored sound meters are moving, like something is making a sound, but when I talk itno the mic, nothing happens to the green colored meters, they just continue to move back and forth with no sound from the interface that I'm using coming through.
What interface are you using?StephanNB wrote: ↑Fri Nov 27, 2020 8:13 pmThe green colored sound meters are moving, like something is making a sound, but when I talk itno the mic, nothing happens to the green colored meters, they just continue to move back and forth with no sound from the interface that I'm using coming through.
What settings do you have in the Device Toolbar?
Hi Steve,
Thanks for getting back with me.
I'm using the MME Audacity setting. I've tried all 3 selections, and still can't get anything.
I'm using the Behringer U Control UCA 202 Interface.
Here's one detail I forgot to mention...while I have everything set to record, on the Interface, there is an "On/ Off" switch for the monitor.
I mentioned that when I set everything on Audacity to record, I have the Record button placed on "record", and have the pause button set so that all I would have to do is click on the Pause to release it from pause and begin recording. While it's on pause, the two green meters are both moving back and forth as if they're receiving sound.(See image ) They are doing this while nothing is connected to Audacity. Then, when I have everything connected to the Interface, the Interface connected to my computer, and Audacity set to record and placed on Pause, if I were to turn off (or on) the monitor switch on the Interface, the meter bars both jump all the way to the end of each meter as if a surge of sound was just made, then they SLOWLY move back down to the position they were in initially and continue moving back and forth as if signaling sound coming in. It does this on both computers. At the same time, the meters on my mixer through which the mic is connected are working, which means there is no microphone problem, and that the mic is working. I'm just completely baffled.
- Attachments
- AUDACITY.png (36.93 KiB) Viewed 291 times
I'd suggest that you ignore Audacity for a minute and look to see what is happening in Windows.
Quit Audacity if it is currently running, and open the Windows Sound control panel (more info here: https://manual.audacityteam.org/man/win ... trols.html)
In the "Recording" tab, you should see a green meter to the right of the (Behringer) USB device icon, and it should move in response to audio input.
When you've got that working, then I expect Audacity will work with your current settings.
The Behringer units come out of the box as plain sound devices. Record from a microphone or other device plugged in, and play computer sound to your headphones. The Monitor switch lets you hear your own live sound on the way to the recording system. You need that if you intend to overdub or sound-on-sound. The Behringer will mix your own live sound with the computer playback. What I call a perfect theatrical mix.
You would think you could do that with Audacity, but sound coming from the computer almost always has a delay or echo which is missing in the Behringer Monitor point.
Hi Steve,
I followed your instructions, and I see the green meter next to USB Behringer device, abd followed the directions in the link you shared with me to get the info from my set up in Windows, but the green meter in the recording tab is there, but it is not working. I've tested the mic, and everything is working with the mixer according to the meter lights when I tap on it.
Do you have a different sound source that you can plug into the UCA202 for testing purposes? Perhaps a CD player?
Also, check your leads - if possible, try different leads.
Steve,
Thanks for all your help, Steve. From all indications, it's the Interface. I plugged the headphones into it, and there's a faint but noticeable ringing sound in it. When I increase the volume for the computer speakers/headphones, an very strange pattern of sound becomes very audible. I then hit the record button on Audacity to see if it was picking up the sound from the Interface, and it is, and then when I increase the volume on audacity microphone level, it produces the wavy sound pattern that you see in the image attached when recorded by Audacity. My (unprofessional) assumption is that this would explain the green meters moving as if sound is being picked up during record, while the microphone is not producing any sound due to whatever is wrong with the interface. Does this sound like a correct assumption?
- Attachments
- AUDACITY 2.png (44.42 KiB) Viewed 262 times
