Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fiacre
Post
by fiacre » Sat Nov 28, 2020 4:38 pm
fiacre wrote: ↑Sat Nov 28, 2020 4:15 pm
waxcylinder wrote: ↑Sat Nov 28, 2020 1:59 pm
Glad you got that sorted
I downloaded the version Izotope gave me.
Unofrtunately I got the same error message as with the 64 bit version.
Maybe Izotope don't work with the lastest versions...
Talked too fast !
Finally, after multiple installation/uninstallation, it finally works !
waxcylinder
Post
by waxcylinder » Sun Nov 29, 2020 2:43 pm
Here is my 32-bit old version running on the latest alpha test build I have for the upcoming 3.0.0
- iZotope Vinyl.png (166.33 KiB) Viewed 80 times
BTW if you do get this vn working do try the Easter-Egg - try removing the four "Screws" by clicking on them one at a time ...
Peter.
