Behringer X32 Mixing Desk
jmholt08
Post by jmholt08 » Wed Nov 25, 2020 2:24 pm
Have downloaded the relevant drivers from the Behringer website but when I attempt to record simultaneous multitracks from an X32 desk to audacity I only have the option of selecting 'In 1-2 Behringer USB' under recording devices. This only gives me a stereo input and not the 16 tracks I need! I can record to these tracks from two channels on the mixing desk. What am I missing? Thanks
Re: Behringer X32 Mixing Desk
Post by steve » Wed Nov 25, 2020 2:37 pm
Please post your "Audio Device Info" (https://manual.audacityteam.org/man/hel ... stics.html)
That will tell us what options are available to Audacity.
See here for how to attach the "deviceinfo.txt" file to your reply: viewtopic.php?f=49&t=64936
jmholt08
Post by jmholt08 » Wed Nov 25, 2020 4:14 pm
Attached, thanks
deviceinfo.txt
(7.12 KiB) Downloaded 11 times
Post by steve » Wed Nov 25, 2020 4:54 pm
Your "deviceinfo.txt" confirms that "In 1-2 Behringer USB" is the only Behringer recording device that Audacity can see.
You will probably be able to access multiple channels with a recording app that supports ASIO, but unfortunately Audacity cannot ship with ASIO support due to licensing restrictions.
If you have experience with C++ programming, then it is possible to build Audacity with ASIO support (let me know if you want to do that), otherwise you could try Reaper or similar.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Nov 25, 2020 7:54 pm
You probably need a DAW (Digital Audio Workstation application). Unfortunately, most DAWs are not free. I don't have a recommendation... REAPER is probably the best "bargain" at $60 USD for the home/small business license with a very-fair upgrade policy. (There is no "lite" or "pro" version, just a pro license.) But. it's highly configurable/customizable so I think it's most popular among techie-type users, and probably not the easiest to learn.
Or, it is a "mixer" so I assume there's a way to record the stereo mix, if you wanted to do that. And, although you can can't multi-track record, you can multitrack mix if you want to record & add tracks later.
jademan
Forum Crew
Post by jademan » Wed Nov 25, 2020 11:54 pm
Also, Cakewalk is now free. See: http://www.cakewalk.com/
jademan
Forum Crew
Post by jademan » Fri Nov 27, 2020 4:16 pm
And here are detailed instructions for creating Audacity 2.4.1 with ASIO support (easier than I thought!):
https://gist.github.com/SteveALee/da24c ... structions
jademan
Forum Crew
Post by jademan » Sun Nov 29, 2020 3:05 pm
And here are instruction for 2.4.2:
viewtopic.php?p=410225#p410225
