Exporting .DTS 5.1 file results in obsolete channels being created
Help for Audacity on macOS.
Oliver M
Operating System: macOS 10.14 Mojave
Post by Oliver M » Tue Nov 24, 2020 5:20 pm
Why don't you have a dedicated bugs forum section?
Anyway...
macOS 10.14.6 (18G6042)
Audacity 2.4.2.0
When importing a 5.1 DTS file into Audacity and exporting the 6 tracks as WAV or AIFF, Audacity adds an obsolete channel to the L, R, Ls and Rs channels. Those obsolete channels are then called L.L, R.R and so on, the obsolete channels are filled with silence only.
Re: Exporting .DTS 5.1 file results in obsolete channels being created
Post by steve » Tue Nov 24, 2020 5:37 pm
Because 99% of "bugs" that are reported turn out to be something else (faulty equipment / user error / incorrect settings / misunderstanding / other software problems / bad drivers / ... the list goes on). It's more informative if we at least know whether the problem is on Windows, Mac or Linux.
So you import 6 channels and on export you get 7 channels?
jademan
Forum Crew
Post by jademan » Thu Nov 26, 2020 2:58 pm
On Windows 10, Audacity 2.4.2:
I tried importing a sample 5.1 DTS audio (from an .mkv file) from the internet (the digital theatre). It imported as six tracks named, xxx 1, xxx 2, etc. (Which played in mono very nicely, by the way).
After changing my Preferences > Import/Export options to "Use Advanced Mixing Options", I exported the tracks as .WAV. When I re-imported the new .WAV file, I got my six tracks back just fine.
However, if, in the export diagram showing the various channels, I adjust the number of exported down to 5, then back up to 7; the resultant file has 7 tracks with the last two zeroed out. Do you suppose this is a bug or the way it was designed to work?
Oliver M
Post by Oliver M » Thu Jan 14, 2021 11:47 pm
steve wrote: So you import 6 channels and on export you get 7 channels?
Read my initial post, please. I am getting 10 channels because the output of channels L, R, Ls and Rs channels add an additional empty output channel each. I think my post was very clear.
Oliver M
Post by Oliver M » Fri Jan 15, 2021 12:59 am
Having to wait for a post to be approved is no fun for a user and totally inefficient, IMHO.
Post by steve » Fri Jan 15, 2021 1:05 am
Please post a screenshot of the "Advance Mixing Options" dialog
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jan 15, 2021 9:22 pm
We block a ton of spam...
Once the secret algorithm trusts you, you'll be able to post instantly without waiting for human approval. ;)
