OK, since Stereo Mix does not appear to be working, try the "WASAPI loopback" method instead.
See: https://manual.audacityteam.org/man/tut ... ndows.html
Strange recording/playback problems
Re: Strange recording/playback problems
Well... That worked fine, all is well.
Thank you Sir.
I bow to your superior knowledge.
I wonder why it changed, I don't remember altering anything.
However, problem solved.
John
Thank you Sir.
John
Perhaps there was a Windows update.
"Stereo Mix" is a very old technology that has been gradually replaced since the introduction of WASAPI with Windows Vista.
Quite probably.
All part of the rich mysteries of Windows 10 updates.
Many thanks. John
Many thanks. John
