Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Site Admin
Post
by steve » Fri Nov 20, 2020 9:19 pm
stayinarrive wrote: ↑Fri Nov 20, 2020 5:45 pm
downloaded 2.4.2 still no sound on playback
OK, so lets take a look at that "Audio Device Info":
1. "Help menu > Diagnostics > Audio Device Info" and wait a few moments for the info to appear.
2. Click the "Save" button and save the file somewhere convenient.
3. Attach the saved "deviceinfo.txt" to your reply (see:
viewtopic.php?f=49&t=64936)
stayinarrive
Post
by stayinarrive » Sat Nov 21, 2020 12:30 pm
Hello Steve, you can forget about this issue. I can now record and play it back. I switched to another set of speakers and set them as the audio out device in Audacity. However I still have no sound otherwise? Any ideas? Windows Media Player problem maybe?
Thank's again.
jademan
- Forum Crew
Post
by jademan » Tue Nov 24, 2020 3:55 pm
stayinarrive wrote:
No sound on play back. I can play previous recordings, and I can record a new one but no sound when playing it.
Realtek USB Codec speakers functioning properly but not in Audacity?
If you haven't already done so, try cycling through the Audio Host: MME, WIndows Direct Sound, Windows WASAPI. Perhaps one of these will work.
stayinarrive wrote: ↑Sat Nov 21, 2020 12:30 pm
Why do you think this might be a WMP problem - Didn't you say "speakers are functioning properly"?
