Revising Default Settings in Gverb
stringed
Post by stringed » Sun Nov 15, 2020 3:31 pm
Is it possible to find the script lines in the Gverb Dll so that I can save my preferred settings? It is so time-consuming to have to re-enter my settings each time the program is opened. I see the line more than halfway down that starts with "Tail level (dB) Early reflection level (dB) Dry signal level (dB) , etc, but there is no way to edit the defaults (no numbers appear. The controls on the Gverb app are changed by sliders. I'm using Windows 10 Home.
Re: Revising Default Settings in Gverb
Post by steve » Sun Nov 15, 2020 3:56 pm
Which version of Audacity are you using? GVerb was replaced by a better reverb effect many years ago.
The current version of Audacity is 2.4.2 and it is available via the Audacity website: https://www.audacityteam.org/download/windows/
Trebor
Post by Trebor » Sun Nov 15, 2020 6:39 pm
Is it possible to find the script lines in the Gverb Dll so that I can save my preferred settings?...
Like other plug-ins, you can save presets ...
Can save presets in Gverb.gif (82.48 KiB) Viewed 36 times
