How do I cut a passage from an existing track and then re-use it on a completely track?
For instance, if doing a Retail Sample, how can I cut a 4 min section from an existing chapter ... and then re-use that same clip in the Retail Sample. I'm trying to avoid re-recording the section if I don't have to.
Cutting and pasting
Re: Cutting and pasting
Copy & paste (like a word-processor), or duplicate the selection ...
https ://manual.audacityteam.org/man/edit_menu_copy_paste_and_duplicate.html
To delete, (after making a copy), see ... https://manual.audacityteam.org/man/edit_menu.html
