The icons wont recognize the list, although it has worked before, said change to data format, but wont work on that either. Any thing I import to music files wont play or burn.
Error said the player may not support the file type or codec that was used to compress the file.
Another message said, you are saving directly to a slow external storage device.
Windows Media used to pop up when I loaded the disc, ready for me to burn, & doesnt anymore.
Windows Media Player has icons in burn list, wont burn
Re: Windows Media Player has icons in burn list, wont burn
I've never used WMP to burn a disc...
I assume you're trying to make an audio CD? You can optionally burn WAV or MP3 "data files" onto a disc and you can play the files on a computer but the disc won't play on a regular CD player.
For more suggestions/hints wee this page.
I use ImgBurn with a Cue Sheet to make sure all of the tracks are in the right order, etc. I start with a known-good cue sheet and then edit it with Windows Notepad. But, ImgBurn can also build a cue sheet
Can you play the files in Windows Media Player? What format are your files? Most burning applications can convert MP3 or other formats to audio CD but try exporting as WAV at 44.100Hz, 16-bit stereo. That's the same underlying format used on audio CDs except Audio CDs are "computer files" in a WAV "package".Error said the player may not support the file type or codec that was used to compress the file.
Have you tried a different blank disc? I've had some bad blanks.Windows Media used to pop up when I loaded the disc, ready for me to burn, & doesnt anymore.
