Hard Limiter
D.Lio333
Operating System: Windows 7
Hard Limiter
Post by D.Lio333 » Wed Nov 04, 2020 10:01 pm
Hi All...
New to the Audacity world. Basic question for a newbie. I was watching a video on youtube that was giving me tips on how to make my voice sound better etc. One of the steps in the video mentioned going to the "Limiter"... The only limiter in my options to choose from was hard limiter. In the video, it looks like:
https://imgur.com/DcklKc0
And his tips were:
Hard Limit for voice-overs
Gain 3-4dB
Limit -3dB (single track) to -4.5dB (multitrack)
Hold 2.0
But in my version of Audacity, it didn't look like the persons in the video, it looked liked below:
https://imgur.com/yt1V2wb
So clearly he has a newer version, but for my older version as Im on Windows 7. Is the above options for the gain limit hold able to be done on my version? I did all the other steps mentioned in the video I saw but left out the hard limit option and it sounded fine. Just learning :) thanks
DVDdoug
Forum Crew
Re: Hard Limiter
Post by DVDdoug » Wed Nov 04, 2020 10:37 pm
The current version of Audacity (2.4.2) will probably work fine on Windows 7 even though it's not "officially" supported.
Audacity's built-in limiter was improved some time ago so you must be using a rather old version of Audacity.
The old hard limiter will clip (distort) the waveform. As a rule, distortion should be avoided but it will alter the character/quality of the sound and you might like what a little clipping does to your voice. So, you can go-ahead and try the old limiter.
The new limiter won't distort the waveform and a reasonable amount will of the "new and improved" limiting have almost no effect on the "quality".
Gain 3-4dB
That's useless unless he knows where you're starting. The Amplify effect will default to whatever up or down gain is required for normalized ("maximized") 0dB peaks.
Then if you hard-limit to -3dB your new reduced/limited peaks will be -3dB. And you can optionally apply make-up gain (or Amplify again) to bring everything up by +3dB, bringing your peaks back to 0dB. And you can run the whole process over again if you want "more".
There is a Recommend Audiobook Mastering Process and it's also good for voiceover with the exception that there usually isn't a -3dB peak limit for voiceover so you can set the limiter to 0dB. But, it's really intended to make your voice "sound better". It will get your levels in-spec (for ACX Audiobooks) and it will check your noise level. ...It's assuming you're starting-out with a good recording of a good performance.
D.Lio333
Re: Hard Limiter
Post by D.Lio333 » Wed Nov 04, 2020 10:40 pm
Thanks much. Yeah I saw that my version I have is the Audacity 2.1.0 I was going to download the latest, but it said it wasn't supported, but if you think it would be fine... I should give it a go?
Trebor
Re: Hard Limiter
Post by Trebor » Thu Nov 05, 2020 12:07 am
And his tips were:
Unless you want a distorted effect, use soft limiter with hold of 10ms or longer ...
https://manual.audacityteam.org/man/limiter.html
D.Lio333
Re: Hard Limiter
Post by D.Lio333 » Thu Nov 05, 2020 12:12 am
Thanks but that doesnt show up on mine as stated with the pic of what showed on his version and mine. I only have Hard Limiter available nothing else on mine.
Re: Hard Limiter
Post by kozikowski » Thu Nov 05, 2020 12:28 am
Even though Audiobook Mastering is designed for ACX/Audible, their requirements are stiff and it's a pretty good assumption if you can pass that, you can submit anywhere else. Their specifications are traceable to broadcast proof of performance.
Fair warning, home readers have some nasty surprises when they set up their new microphone on the kitchen table like the manufacturers keep insisting they can do. In particular background noise at -60dB. In English, your room noises have to be 1000 times quieter than your voice. If you can tell your computer is on just by listening, it's going to be a long day.
Don't fall in love with hard limiter. As Trebor, above, that's the effect used for taxicab dispatch, two-way radio, and air-traffic controller.
"United Two Five, clear for approach two four right, contact ground control one two eight point two."
https://www.kozco.com/pix/LAX24R-Approach.png
Re: Hard Limiter
Post by kozikowski » Thu Nov 05, 2020 12:31 am
Are you sure you're in Audacity 2.4.2?
Screen Shot 2020-11-04 at 4.29.35 PM.png (54.44 KiB) Viewed 748 times
D.Lio333
Re: Hard Limiter
Post by D.Lio333 » Thu Nov 05, 2020 12:34 am
No. I wrote in the first reply, I have 2.1.0. I was going to get latest, but it says its not supported by windows 7. First reply to this mentioned they thought it would be okay even though it says not supported. Shrugs.
Re: Hard Limiter
Post by kozikowski » Thu Nov 05, 2020 12:45 am
OK. Try this. Attached: "limiter.ny." It's a Nyquist plugin dated May 2015 and may need to be installed to get all the fancy tools.
limiter.ny
(1.52 KiB) Downloaded 15 times
Re: Hard Limiter
Post by kozikowski » Thu Nov 05, 2020 12:52 am
Sometimes that means it will work OK, but if you run into trouble, we may not be able to help you. In the same sense that Microsoft recently said they no longer support Win7. Machines don't just fall over dead, and no, I'm not going to put my Win7 computer out in the garage.
See if that limiter plugin works.
