90s sound effect alike
crazyfool00
Post by crazyfool00 » Sun Nov 01, 2020 12:58 pm
Audacity 2.3.3 for Windows 10
Hi there,
How are you? I hope you are safe from this pandemic!
I have created a short track using a 90s soundpool, but the audio quality is "too" high for such style and I would like to make it sound as it were recorded back then. Could you please tell me what steps I should follow? Thanks a lot and have a nice day!
Trebor
Re: 90s sound effect alike
Post by Trebor » Sun Nov 01, 2020 2:05 pm
I have created a short track using a 90s soundpool, but the audio quality is "too" high for such style and I would like to make it sound as it were recorded back then ...
This free, (Windows only), plug-in has cassette, vinyl, & CD emulations ...
https://youtu.be/_qzCVSF_D-4?t=14
crazyfool00
Post by crazyfool00 » Sun Nov 01, 2020 3:20 pm
Thanks a lot, but I meant that I would like to save it with that quality. My bad, sorry!
DVDdoug
Forum Crew
Post by DVDdoug » Sun Nov 01, 2020 4:31 pm
I'm not sure what "sound' you are after. Can you try to explain what you want? More/less bass or more/less highs? Some background noise/hiss? Do you want the sound of a low-quality MP3? ...It's usually easier to degrade sound than to improve it.
There was nothing wrong with 1990s sound quality. (The music, recording and production is a matter of taste.) When CDs were introduced in 1982 consumer recordings suddenlybecame "better than human hearing". Analog studio recording was getting really good by the 1970s but there was no easy-standard way to get that sound at home before the CD.
crazyfool00
Post by crazyfool00 » Sun Nov 01, 2020 9:14 pm
Indeed, you're right. I am looking for lower MP3 audio quality. Thanks a lot!
Post by steve » Sun Nov 01, 2020 10:00 pm
Try exporting as MP3. Set "Bit rate mode" to "Constant" and "Quality" to 64 kbps or less (the lower the bit rate, the lower the quality).
The MP3 could be imported back into Audacity (along with its reduced sound quality) for further editing / processing, or if you just want to convert it to another format.
crazyfool00
Post by crazyfool00 » Sun Nov 01, 2020 10:05 pm
I'll try right now! Is there any effect I shoud add? How about the project rate? Thanks a lot for your patience and support!
Trebor
Post by Trebor » Mon Nov 02, 2020 1:23 am
... Is there any effect I shoud add? ...
The free plugin I directed you to has a cheap mp3-player effect ...
NB: illogically the *rate knobs are maximum clockwise for maximum cheapness.
cheapest settings.png (136.02 KiB) Viewed 283 times
https://youtu.be/3GNGXXZeW_g?t=490
crazyfool00
Post by crazyfool00 » Tue Nov 03, 2020 9:57 pm
Thanks a lot!
