Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
tlm
Post
by tlm » Fri Oct 30, 2020 2:05 pm
Trebor wrote: ↑Fri Oct 30, 2020 12:11 am
Paul-L's DeClicker plug-in can be configured to DeThud,
(as clicks & plosive-thuds are similar phenomena on different timescales)
Thanks, Trebor. I did some tests using the DeClicker plug-in using the settings you showed, and it did, in fact, get rid of smaller clicks that the PopMute plug-in missed. The combination of these two definitely improved the audio I'm working on, and I appreciate that. At the same time, it must be admitted that most problems are still there, just less intense.
Maybe some day I'll take the time to implement the idea I mentioned above after learning how to write plug-ins.
Thanks again.
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Fri Oct 30, 2020 3:43 pm
tlm wrote: ↑Fri Oct 30, 2020 2:05 pm
... I did some tests using the DeClicker plug-in using the settings you showed....
The DeClicker settings shown are not written in stone;
e.g. you will have to adjust the threshold on a case-by-case basis ...
- other DeClicker settings.gif (70.62 KiB) Viewed 84 times
