I did not see any place to turn off make up gain. It just seems to default to -1 dBFS.steve wrote: ↑Sun Oct 25, 2020 9:00 pmYou can always turn off "Make up gain" and then apply the Amplify or Normalize effects with the amount of make up gain that you want.joe sixpak wrote: ↑Sun Oct 25, 2020 7:21 pmit should give me the option for the amount of make up gain to use if any.
Note: I am on 2.0.6 which seems to be the last audacity for XP. Maybe later versions are different.
There is an option to add make up gain to 0dBFS which I left unchecked as I did not want any make up gain.
Unless this is another non intuitive reverse option where if I had checked it then it would NOT add the gain?
Just checked it and it added the gain when I had the box checked.
If it did not add make up gain *I* could always amplify to get any amount of gain added back.
What it should do is either nothing wrt gain, or else ask what level to raise the compressed result back up to.
It should never default to raising the gain to any arbitrary level on its own.
I also note that the compress ratio is confusing too. Instead of changing the ratio on the chart like A&H does it changes the threshold setting (or what I would expect would be the threshold setting) and the threshold slider moves the threshold as well as the start of signal.
Now maybe the chart makes sense which is why I asked the original question but to me and what I see on the Qu32 it is very confusing whatever it is audacity is really trying to show me there.
