.mp3 file size reduction
sft.brazil
Post by sft.brazil » Sun Oct 21, 2007 6:51 pm
If one can ... how can one reduce .mp3 file size in Audacity Stable?
colin_e
Re: .mp3 file size reduction
Post by colin_e » Mon Oct 22, 2007 9:36 am
You need to configure the MP3 encoder options for LAME to reduce the bitrate. Unfortunately I don't have Audacity on this machine to tell you the exact menu options, but I think it's under "Configure".
Ideally you would not only reduce the bit rate, but also enable Variable Bit Rate (VBR) encoding, assuming your target device supports it. Unfortunately I haven't found out how to do this through Audacity yet.
Regards: Colin
AndyNewton
Post by AndyNewton » Mon Oct 22, 2007 9:51 am
In Audacity 1.2.6 click on ....
Edit (menu)
Preferences
File Formats
MP3 Export Setup - Bitrate - Select a value from 16 to 320 (thousand bits per second)
OK
Audacity will remember the selected bitrate for all future mp3 exports, until you change it again.
Selecting a small value such as 32 will reduce mp3 file sizes, but will also reduce the mp3 sound quality.
