My hand made vocal booth and voice test
mikifan88
Operating System: Windows 7
Post by mikifan88 » Sat Oct 10, 2020 1:28 pm
Hey everyone
This is my first post on this forum, although I've been browsing it for years.
For several years I have been dealing with amateur podcast recording. Most of the time I recorded with the worst quality microphones. Friends praised my voice and persuaded me to become a professional voiceover. I quickly realized that it would be impossible to get a good recording without a studio. Searching the internet, I found information that a vocal booth can help a lot in recording. Having a limited budget, I decided to do it myself. As an example, I chose a vocal booth from Isovox. I used stone wool to make it.
I am writing because I would like to publicly show my project. I would also like to ask you to evaluate the quality of the recordings. I'm not sure if the sound I'm getting is good for me to think about producing recordings for podcasts, commercials, jingles and radio productions.
I am sending the test for your evaluation. And a short photo report.
I will be grateful for all suggestions!
milk test.wav
(1.1 MiB) Downloaded 59 times
mikifan88
Re: My hand made vocal booth and voice test
Post by mikifan88 » Sat Oct 10, 2020 2:24 pm
Photos part 1
mikifan88
Post by mikifan88 » Sat Oct 10, 2020 2:27 pm
photos part 2
Post by kozikowski » Sat Oct 10, 2020 6:42 pm
Terrific work. I can't listen right this second, but I expect it to sound perfect.
I mastered it for audiobook submission and it passes with no other filters or corrections needed.
milk_test-Mastered.wav
(1.1 MiB) Downloaded 51 times
Screen Shot 2020-10-10 at 11.14.38.png (25.66 KiB) Viewed 865 times
With reference to the last picture in the last post:
Screen Shot 2020-10-10 at 11.34.19.png (196.39 KiB) Viewed 865 times
I know I'm the only person on Earth who does this, but what happens if someone hands you an A4 or letter size paper to read? Where are you going to put it?
Are you reading from your phone? There have been posts from people who got radio or other radiation interference from their phone or tablet to the microphone or cable. Airplane Mode may not be enough. You may also have to turn off BlueTooth, assuming the connection is separate.
We had one posting from someone who's tablet screen was causing problems. If you do get whining or buzzing problems, do a recording where you turn the device off and see if the noise goes away.
As we go.
Post by kozikowski » Sat Oct 10, 2020 6:56 pm
Sounds good to me.
Which microphone is that? It doesn't have the harsh, overly crisp, sharp, essing that some other microphones do. It sounds like a natural voice.
That's a raw sound file, right? No effects or filters?
Post by kozikowski » Sat Oct 10, 2020 7:27 pm
I sew. I'm a "seamster." I keep seeing the nightmare of sewing the rockwool covers.
mikifan88
Post by mikifan88 » Sat Oct 10, 2020 8:25 pm
Passes all the tests? That's a great message!
I was worried that there would be some reverberation, or worse, a sound like a cardboard. I spent a lot of time on this box. I think it took me almost a month to work on everything, including the binding of the fabric. Something like 80 hours.
Cutting stone wool was not so bad. More work I had to put in the protection of the specific parts with foil and fabric. Buiding this i had in mind that it must be solid to last long. Everything, as in the original Isovox, is joined with Velcro and zippers, so its should be fast to transport all. However the same as in the oryginal, box is quite large. I was also searching for information whether to protect wool with foil or not and if it can affect the sound absorption. I found that rock wool is non toxic for lung, however more studies are neded ;-) So i decided to shut all the parts with foil. I guess it may echoes the sound a litlle?
The microphone is Rode NT1A. I connected it to the 3rd Generation Scarllett Solo Interface. Such equipment was recommended to me by a friend who is dealing with music. I know that there is a lots of it and many doesnt had to suite my voice. At this point i have nobady to go to to test other mics with my voice. Thats the most expensive mic that i can get.
The recording is clean with no editing, no filters or enhancement or normalization. Gain is set to 50%. I was afraid that the recording is gonna be a bit too quiet, as the image is not too big.
I am already recording my first materials and I do it using a telephone and a wireless mouse to scroll through the text. As you write, I recorded the sound of fried mosquitoes. I was able to get rid of it by changing the usb input on my laptop. Fortunately! I read that it is a big problem!
DVDdoug
Forum Crew
Post by DVDdoug » Sat Oct 10, 2020 9:16 pm
I've never had my hands on one, but it has a great reputation and for most applications it's probably as good as any mic at any price.
It's good to have strong acoustic & analog signals to overcome noise, but the digital level is not that critical as long as you avoid clipping. The position of the knob isn't important either. It's the actual level you're getting that's (somewhat) important.
That's noise from the USB power getting into the preamp in your interface. A different computer can make a difference and some interfaces are more immune to this than others. Of course, an interface with it's own separate power supply is completely immune to that particular source of noise.
Post by kozikowski » Sat Oct 10, 2020 10:01 pm
The first thing the sound hits should be sound deadening material or rock wool, not hard foil. You can go with it as it is, but I bet the vocal quality "opens up" if you strip out the foil. This should be a snap if everything has zippers.
At minimum the inside foil.
I wondered about that from earlier experiences with asbestos. No mention of health hazards with rockwool.
There's another Beginner problem. Do Not change anything once you start a job. ACX is expecting the beginnings and ends of chapters, the chapters themselves, and the start and end of the book to all match. There is no improving the microphone in the middle of a book. That dooms you to read the whole thing over.
There was a poster who moved houses in the middle of a book. It was an adventure getting the two halves of the book to match.
Post a milk clip without the foil.
Trebor
Post by Trebor » Sat Oct 10, 2020 10:51 pm
Attachments milk test.wav (1.1 MiB)
You need to equalize to correct for the resonance of the booth ...
only suggestion, (maybe too much treble).
suggested equaiization.gif (70.16 KiB) Viewed 848 times
''milk test'' before-after.flac
(1.02 MiB) Downloaded 44 times
before-after equalization
red=before, green=after.gif (277.75 KiB) Viewed 847 times
Also you have pops caused drop-outs, e.g. at 5.015 seconds, (between "creamy" and "vitamin").
That's due to the computer not listening for a fraction of a second when the recording was made,
e.g. Audacity being interrupted by other software.
