Can't open files
Help for Audacity on macOS.
punkin
Can't open files
Post by punkin » Fri Oct 09, 2020 3:40 am
I'm on a 2014 Mac Air running Catalina 10.15.7 and Audacity 2.4.2.
Before I moved to Catalina, Audacity developed a quirk: I could no longer click on an Audacity or .wav file to open it in Audacity (which is set at my default app). The only way to open them was to start a new Audacity session and drag the file into it.
I downloaded the new Audacity tonight. Now I can't open the files any way at all. I click and nothing happens. I Control-click and choose "Open" or "Open with Audacity", and nothing happens. I start a new session and try to drag the file into it; I get a message that to open an .aup file, I need to click "Open file".
Of course I'm on deadline tonight. :cry:
I'd appreciate any help at all, the faster the better!
waxcylinder
Re: Can't open files
Post by waxcylinder » Fri Oct 09, 2020 8:54 am
That sounds like this logged bug:
https://bugzilla.audacityteam.org/show_bug.cgi?id=2437
Mac: "Open with" fails when Audacity is running
which we know about but haven't found a way to fix.
And see alo9s this related bug:
https://bugzilla.audacityteam.org/show_bug.cgi?id=2510
Mac: Drag&Drop of a project file onto Audacity in Apps bar or Finder fails if Audacity is active in the Apps bar
