High Sierra ok?
Help for Audacity on macOS.
johnnydub
High Sierra ok?
Post by johnnydub » Sun Oct 04, 2020 9:15 pm
Hi again
Is it ok to use the new Audacity with High Sierra and a Focusrite Solo? I have an older MacBook Pro, and don't think I can use a more recent OS on it.
Thanks,
John
Re: High Sierra ok?
Post by kozikowski » Sun Oct 04, 2020 10:00 pm
Audacity 2.4.2 seems to work well on my two High Sierra machines. I get an occasional little reminder that I really should go to Mojave. I think you can go as far as Mojave without running into too many difficulties.
Catalina is the first very serious change. Catalina is a "new" OS. Increased security and no more 32-bit apps. You don't realize the older apps and settings you rely on until they vanish.
My "television" for one example, is a 32-bit app.
Mojave comes with intrusive nag screens for upgrading.
Re: High Sierra ok?
Post by kozikowski » Sun Oct 04, 2020 10:08 pm
There are no production-ready installers for Audacity 3.0.0.
2.4.2 is fully supported.
