Audacity won't let me indicate the Focusrite Solo when i start recording
Help for Audacity on macOS.
johnnydub
Post by johnnydub » Sun Oct 04, 2020 9:12 pm
Hello,
When I plug in the Focusrite Solo, Audacity doesn't seem to recognize the Solo. How do I fix this?
Re: Audacity won't let me indicate the Focusrite Solo when i start recording
Post by kozikowski » Sun Oct 04, 2020 10:06 pm
Plug in the Solo, let it settle, and then start Audacity.
You can also Audacity > Transport > Rescan....
