When playing back recorded material I get a pop or a clicking noise in my headset. It's not in the recording itself . I was wondering what causes it and if it can be fixed.
Thanks in advance for the help
Bob
Audacity 2.4.2
Windows 10
Playback noises
Re: Playback noises
Wireless?in my headset.
If you have good wired headphones, you can use them to troubleshoot sound problems. They're super simple and don't depend on a quiet room, environmental friendliness, or radio connections to work.
Wireless is always subject to the radio connection and if your app doesn't know how to deal with tiny radio service interruptions, it can sound worse than it is.
Headsets are a problem. The bluetooth connection has to maintain perfect quality in both directions at the same time. It doesn't and that can give you odd interruptions and noises.
Let us know.
Re: Playback noises
So, it happens with all audio files including "known good" files?It's not in the recording itself.
Does this happen only with Audacity or also with Windows Media Player (or whatever player software you normally use)?
Does it happen when you're not playing any sound?
Re: Playback noises
No, wired ......and ONLY with recorded Audacity material.
Bob
Bob
Re: Playback noises
So, it's actually a recording problem...
It could be dropouts (usually related to multitasking causing the audio to be interrupted). If it's not dropouts, noise is an analog or acoustic problem.
