Hello.
In my workflow, I constantly use the menu item 'Export/Export multiple'.
Then I check the box 'Include audio before first label'. I also replace 'File name prefix' with always the same string of characters (let's say "A").
Is there a way to set these preferences as defaults? The first item is especially important to me, as I occasionally forget to check the box myself, which completely derails my workflow.
Thank you very much in advance.
Choose defaults in the 'Export multiple' menu box
Re: Choose defaults in the 'Export multiple' menu box
No there isn't.
What is the benefit for your task of not adding a label for the start of the first exported file? In other words, why do you add a label for each exported file except the first one?
