I have an ioniTTUSB that is several years old. i have a Mac with the latest software. Does Audacity support this? How can I get it to work?
Thank you for any help.
ioniTTUSB
waxcylinder
Re: ioniTTUSB
Please see this set of tutorials: https://manual.audacityteam.org/man/tut ... to_cd.html
particularly this one: https://manual.audacityteam.org/man/rec ... ables.html
