I can't figure out how to get Audacity to stop opening up my music when I simply click on an itunes selection.
Before I would listen through audacity and just click no to save changes so I wouldn't end up with duplicates in ausdacity of itunes music. (And now it won't play--but that is a separate issue) I already deleted Audacity 2.1.0 from the doc. I'm using Mac OS 10.14.6 Mohave.
Stop Audacity from automatically opening iTunes songs
Re: Stop Audacity from automatically opening iTunes songs
Right+Click or Control+Tap one of the songs > Get INFO. Down at the bottom of the info post is Open With:simply click on an itunes selection
Pick the application you want to use and whether you want this to happen to all songs like this.
Thank you so much, at least I can listen without audacity opening up by clicking control/tap and then choosing iTunes. It even says iTunes by default.
But... if I click on the iTunes icon for the song directly it still is launched in audacity??? Any other ideas.
Mac OS Mojave 10.14.6, and Audacity 2.1.0
Anne
Anne
