Audacity stopped recordimg
TJB
Post by TJB » Wed Sep 09, 2020 1:59 pm
When I open Audacity, it will not record ... almost like the button is stuck. I've rebooted the computer several times. Any thoughts?
Re: Audacity stopped recordimg
Post by steve » Wed Sep 09, 2020 2:06 pm
If the "Pause" button becomes stuck down every time you try to record, it's probably because you've accidentally enabled "sound activated recording". You can turn that off in "Transport menu > Transport Options".
