unable to listen to track while recording
dwardo14
Post by dwardo14 » Wed Sep 09, 2020 6:32 am
please help,
I am unable to listen to the backing track whilst recording on another. If I put the overdub or playthrough on then try and record I get the time line disabled red flags come up and it just freezes.
we have recorded on it without this issue happening for some time now so a bit gob smacked as to why it is suddenly doing this??
Re: unable to listen to track while recording
Post by steve » Wed Sep 09, 2020 1:04 pm
Overdub -> On (enabled)
Software Playthrough -> Off (disabled)
In the Device Toolbar:
host -> MME
Recording device -> Your microphone
Playback device -> Your headphones
dwardo14
unable to listen to track while recording....more info
Post by dwardo14 » Thu Sep 10, 2020 6:41 am
I have put the overdub on and the software playthrough off mme and rubix 44 input mike and output but still no joy the red flags come up .....disable timer and the recording just stops there, very very frustrating it has been working perfectly up till now so need to get to the bottom of it. regards Ed
Reason: Topics merged.
dwardo14
Post by dwardo14 » Thu Sep 10, 2020 6:58 am
I put the overdub on playthrough off mme rubix mike in rubix speakers out still getting the red flags and the recording just freezes as soon as i press the record button
dwardo14
Post by dwardo14 » Thu Sep 10, 2020 8:15 am
could it be something to do with the bit rate or some other setting which I have overlooked......?
though I haven't changed any and it was working fine up until now
Post by steve » Thu Sep 10, 2020 8:27 am
What do you mean by "the red flags"?
Are you referring to the green / red triangle on the left hand end of the Timeline (time ruler)?
dwardo14
Post by dwardo14 » Thu Sep 10, 2020 8:45 am
yes the 2 upside down triangles just sit there and not able to record
dwardo14
Post by dwardo14 » Thu Sep 10, 2020 8:48 am
the last time it happened you mentioned about setting the bit rate and that fixed the issue and we have been recording happily since then.
I cant remember what the settings were but I havent touched them so all seems a bit odd
Post by steve » Thu Sep 10, 2020 9:35 am
Your previous topic is here: viewtopic.php?f=46&t=110527
Let us know how you get on.
dwardo14
Post by dwardo14 » Thu Sep 10, 2020 10:43 am
checked the rate in the bottom left is 44100 and hasnt been changed
very frustrating still cannot record and hear the backing track the red triangles still appear
