Too many manuals! (2.4.2)
Help for Audacity on macOS.
eleanorb
Post by eleanorb » Tue Sep 08, 2020 3:00 pm
I had trouble downloading the manual, and I see now that I must have done so five times, because I have five copies of all the .html bits! Is there any way I can get rid of this excess stuff? If I uninstall Audacity, will that remove all the manual pieces also? Eleanor
MacOS 10.15.6 + MacBook Air 2020
billw58
Re: Too many manuals! (2.4.2)
Post by billw58 » Tue Sep 08, 2020 4:51 pm
Just drag them into the Trash. Re-installing Audacity will not get rid of them.
-- Bill
eleanorb
Post by eleanorb » Sat Sep 12, 2020 1:12 pm
It is hard to find them all! If I uninstall Audacity, that won't also remove the manual(s)?
billw58
Post by billw58 » Wed Sep 16, 2020 1:15 am
No, uninstalling Audacity will not get rid of the manuals you downloaded separately. Audacity doesn't know about those manuals you downloaded.
Where did you download the manual from? All the "html bits" should be inside one folder. Just delete that folder.
-- Bill
