Error code 9987
Etoft21sports
- Operating System: macOS 10.14 Mojave
Error code 9987
I have a yeti microphone and I keep getting the error 9986. My sample rate is set to 44100 so does anyone know any trouble shooting steps I can make? Thank you
Re: Error code 9987
From the manual:
(https://manual.audacityteam.org/man/err ... html#codes)
9996 Invalid device: this means that the sound device is not valid, if it is an external sound device:
* it may have been unplugged
* you may have a faulty or loose connection
* you may have a bad lead
* the device itself may be faulty.
