Is there a simple list of options one can use with "do_command"?
Emerogork
Re: Is there a simple list of options one can use with "do_command"?
Post by Emerogork » Sat Sep 05, 2020 6:38 am
steve wrote:
Thu Sep 03, 2020 8:32 pm
Emerogork wrote:
Thu Sep 03, 2020 6:52 pm
After making three corrections in the command line interface code, I finally got it to work.
What were they?
Forgive me, I cannot believe how much I screwed up on this one. I have three very large programs that I am working on almost simultaneously. I am linking python to Audacity, python to Excel, and a huge code in python to help me manage my insulin. All three are receiving code that is new to me.
I responded to what I thought was in error in the pipe_test not realizing that the open call was using a variable instead of a file name and "corrected" it accordingly. I made it all worse by posting the mix up.
What's more, I then opened a different browser, attempted to log in and messed up the password enough times that I became locked out and had to use captcha numerously to get back on. YUCK....
Reason: fix quote tags
Emerogork
Post by Emerogork » Sat Sep 05, 2020 7:08 am
Ok, for fear of the worst, I have made significant head way getting python to talk to Audacity.
Unless someone can suggest why the pipe_test.py is not a good choice, I plan to use it unless shown otherwise. It is short, simple, and is performing the way I want.
The loop runs as I want except for one command.
while T < 5:
T += 1
t = str(T)
print(" Track name " + t + " = " + ThisList[T])
do_command("Record1stChoice")
do_command("AddLabel: Text = ThisList[T]")
time.sleep(10)
do_command("Stop")
print(" Done")
As it is, this program will generate five tracks of 10 second recordings.
Each track will have blank labels.
Eventually, T will be 23 and time.sleep(10) will be an hour.
Right now, t = 5 and sleep is 10 seconds.
I would like to have the label for each track reflect the ThisList[T] entry in the list.
The ThisList list contains 4 letter codes for each entry.
What is wrong with my AddLabel command?
Is there a different way to do this?
(Apparently a file with a .py extension will not attach. yes?)
Post by steve » Sat Sep 05, 2020 9:46 am
You will be able to attach it by adding ".txt" to the file name. For example: "my_program.py.txt"
Post by steve » Sat Sep 05, 2020 10:26 am
Your label command:
Code: Select all
but the manual says:
AddLabel: - (Action) Add Label at Selection - (Parameters) none - (Description) Creates a new, empty label at the cursor or at the selection region.
"Text =" is not a valid argument (parameter), because "AddLabel:" does not take any arguments.
You will need to create an empty label (with "AddLabel:") and then add the text to the label with "SetLabel: Label=[label number] Text=[label text]".
For example, this will create a point label "Hello" at time = 5 seconds, and a region label "World" from 15 to 16 seconds.
Code: Select all
SelectTime:End="5" RelativeTo="ProjectStart" Start="5"
AddLabel:
SetLabel:Label="0" Text="Hello"
SelectTime:End="16" RelativeTo="ProjectStart" Start="15"
AddLabel:
SetLabel:Label="1" Text="World"
(Note that double quotes, if used, will probably need to be escaped in your script)
Emerogork
Post by Emerogork » Mon Sep 07, 2020 7:13 am
AddLabel:
AddLabel:
This doesn't seem to work for me. I would like to send the code to Audacity using do_command code. I am still experimenting with the pipe_test.py program because it is short and has worked up until now. Maybe I do have to use the other program.
Insights welcome.
Post by steve » Mon Sep 07, 2020 11:09 am
What's happening?
Post by steve » Mon Sep 07, 2020 11:11 am
Perhaps worth trying the commands using pipeclient's command line interface - by default, it prints Audacity's response to each command, so you can see immediately if a command fails.
This is what I get:
Emerogork
Post by Emerogork » Mon Sep 07, 2020 2:59 pm
What's happening?
Oop. sorry for the lame entry.
I get the track note but no wording in the label.
It is as if all I did was hit ^b.
No "Hello" and no "World".
Post by steve » Mon Sep 07, 2020 4:40 pm
Does your project already have some labels? If it does, then the label index number will not be correct in
If you're using "pipe_test.py", you will need to escape the double quotes:
Code: Select all
"SetLabel:Label=\"0\" Text=\"Hello\""
Have you tried from the command line with pipeclient? Can you reproduce my results if you start with a new, empty project?
Emerogork
Post by Emerogork » Mon Sep 07, 2020 7:51 pm
I will explore pipeclient but it may take a while to report back. I have two other large projects taking stage.
Thanks..
P.S., I did try the "\" escapes in the line pipe_test.py but still no text being sent to the label. So close.....
