I really hope you can help me here. I recorded a podcast for almost two hours of work and then while playing it to edit, the program crushed.
I check the temporary files, and hoped that auto-recovery will work - they didn't.
Somehow, the files were saved in the folder, however, now when i open audacity i get a message:
"project check of xxxxx found 26 orphan block files. these files are unused by this project but might belong to other projects. They are doing no harm and are small".
I chose the option "continue without deleting"
I see all the one-hour recording (there are sound wave) however, the file doesn't play any sound. I tried to export it as well but nothing happens.
Please help
Thanks
